3 Point Lift
   / 3 Point Lift #1
Hinomotoman
Western NC
LS R3039, Hinomoto E2604, Hinomoto N239, Case IH 1140, White Field Boss 31
I have a Mitsubishi built Case International 1140. When the lift get up about 2/3 the way, it slows the engine down. When it passes this point, the engine resumes it's normal RPM's. It doesn't choke the engine completely down, just makes it lug. This happens with no implement on the lift. Any ideas what's wrong?:confused:
Eugene
   / 3 Point Lift #2
Is all the linkage connected correctly.
Is there any mechanical binding.
If operating the 3pt is causing the engine to load up, is related to the hyd flow against a resistance.
If you install a hyd gage in the hyd system, you can use it to monitor and trouble shoot the hyd system.
Will the 3pt lift a heavy load?
   / 3 Point Lift
All linkage is connected correctly. No mechanical binding. Will lift anything I have. Don't have a gauge yet. Once it gets past the 2/3 position, it turns back to normal the rest of the way up..
Eugene
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2020 PRINOTH...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A54757)
UNUSED...
2002 MACK RD688S ROLLOFF TRUCK (A51406)
2002 MACK RD688S...
2015 Ford F550 Altec Bucket Truck (A52377)
2015 Ford F550...
