3 point lift lever is sticky YM1510D
   / 3 point lift lever is sticky YM1510D #1
yellowdog5
Yanmar
When I lower or lift the 3 point hitch on my tractor there is a sticky spot, it does not operate smoothly, it stops and I have to jiggle the lever a little or force it through the tight spot. Does anyone know what's wrong?
   / 3 point lift lever is sticky YM1510D #2
Have you examined all the external linkage for possible tight spots?
   / 3 point lift lever is sticky YM1510D #3
In addition to a bent/binding linkage, look for wear points at connections on those linkages. A slightly out of round hole or a grooved pin can cause a snag during movement.
These are much simpler to fix than internal hydraulic issues so check closely. A bushing may be all the fix you need or straighten a linkage.
Thanks Coy Patton I will check it out this evening.
winston1 yes I did but I dont think I understood what to look for, I'll check it out tonight.
   / 3 point lift lever is sticky YM1510D #6
I think, in other words. Look for any wear spots on the linkage itself. Such as wore spots on them such as paint being removed as it rubs together etc..
The linkage was the problem, I oiled it well and it's running smoothly now, going to order some new parts.
Mower King Brush Cutter (A53317)
Mower King Brush...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A55745)
2015 VANTAGE...
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
