3 point lift lever is sticky YM1510D
   / 3 point lift lever is sticky YM1510D #1
yellowdog5
Yanmar
When I lower or lift the 3 point hitch on my tractor there is a sticky spot, it does not operate smoothly, it stops and I have to jiggle the lever a little or force it through the tight spot. Does anyone know what's wrong?
   / 3 point lift lever is sticky YM1510D #2
Have you examined all the external linkage for possible tight spots?
   / 3 point lift lever is sticky YM1510D #3
In addition to a bent/binding linkage, look for wear points at connections on those linkages. A slightly out of round hole or a grooved pin can cause a snag during movement.
These are much simpler to fix than internal hydraulic issues so check closely. A bushing may be all the fix you need or straighten a linkage.
Thanks Coy Patton I will check it out this evening.
winston1 yes I did but I dont think I understood what to look for, I'll check it out tonight.
   / 3 point lift lever is sticky YM1510D #6
I think, in other words. Look for any wear spots on the linkage itself. Such as wore spots on them such as paint being removed as it rubs together etc..
The linkage was the problem, I oiled it well and it's running smoothly now, going to order some new parts.
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
JOHN DEERE 600 TRACTOR BRUSH GUARD (A58376)
JOHN DEERE 600...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
Margaritaville 5 O' Clock Somewhere Sign (A57454)
Margaritaville 5...
JMR 40" Mini Grapple (A57149)
JMR 40" Mini...
2014 Jeep Cherokee Sport SUV (A56859)
2014 Jeep Cherokee...
