3 point lift jerky on Kubota M6800?
   / 3 point lift jerky on Kubota M6800? #1
Mseriesfreak
I just bought a 02 M6800 2wd cab with 1900 hrs.I hooked my heavy JD609 bushog to it yesterday and when you raise it up it is pretty jerky.The rotary cutter is 6' and is very heavy.I can pull in and out on tractor PTO shaft about a 1/4"Is this normal?
   / 3 point lift jerky on Kubota M6800? #2
a jerky 3pt on an M series never heard of that as far as the pto shaft that not normal at all
   / 3 point lift jerky on Kubota M6800? #3
I think 1/4 " movement of pto shaft is OK. Have you changed hyd filter since you purchased tractor? If so how long ago?
I have not changed the filters.Does the valve under the seat have anything to do with my problem or it is just for lowering the speed of 3 point hitch?
   / 3 point lift jerky on Kubota M6800? #5
It is just for the lowering speed of the 3 point hitch.
   / 3 point lift jerky on Kubota M6800? #6
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2013 Nissan Rogue SUV (A51694)
2013 Nissan Rogue...
2019 Ford F-450 4x4 Utility Truck, VIN # 1FT8W4DT8KEF27612 (A51572)
2019 Ford F-450...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
Electric Concrete Mixer (A51573)
Electric Concrete...
2002 International 4300 Cab and Chassis Truck, VIN # 1HTMMAAP02H548742 (A51572)
2002 International...
