3 point lift jerky on Kubota M6800?
   / 3 point lift jerky on Kubota M6800? #1
Mseriesfreak
I just bought a 02 M6800 2wd cab with 1900 hrs.I hooked my heavy JD609 bushog to it yesterday and when you raise it up it is pretty jerky.The rotary cutter is 6' and is very heavy.I can pull in and out on tractor PTO shaft about a 1/4"Is this normal?
   / 3 point lift jerky on Kubota M6800? #2
a jerky 3pt on an M series never heard of that as far as the pto shaft that not normal at all
   / 3 point lift jerky on Kubota M6800? #3
I think 1/4 " movement of pto shaft is OK. Have you changed hyd filter since you purchased tractor? If so how long ago?
I have not changed the filters.Does the valve under the seat have anything to do with my problem or it is just for lowering the speed of 3 point hitch?
   / 3 point lift jerky on Kubota M6800? #5
It is just for the lowering speed of the 3 point hitch.
   / 3 point lift jerky on Kubota M6800? #6
2013 F-550 Bucket Truck (A53472)
2013 F-550 Bucket...
2015 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2018 Gatormade 20+5 Gooseneck Trailer (A53472)
2018 Gatormade...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
JOHN DEERE 560M LOT NUMBER 37 (A53084)
JOHN DEERE 560M...
