3-Point Hitch 3 point lift capacity
   / 3 point lift capacity #1
GasNSteering
Zoo Jersey
I was wondering what the 3 point lift capacity is for my Ford 1000. I have the manual and dont see it listed anywhere.
   / 3 point lift capacity #2
Not sure right off hand.. what ya planning to do with it?
i used to have one and had a 3pt sprayer on it with a water tank. i'm sure she picked up about 1000# with no problems.. hopefully someone else has the actual answer for you.. it's been 20 years since I drove a 1000.
soundguy
   / 3 point lift capacity #3
I was not able to find that information for my 1700 or any other hundred series Ford, I don't know why it is not published. My owner's manual does not have that #. Ford 1000 and 1700 are very similar in size, HP and weight. I have compared the dia of my lift piston and it is very close to a TC-30. The hyd pump relief is set just above 2000 psi and TC-30 can lift about 1700 lbs. I have no doubt that Ford 1000 and 1700 at the very least lift 1300-1500 lbs and for sure 1000 lbs as Soundguy suggested. I pick up 800 lbs tiller with no problems and pulled out 6" dia wooden post buried 3 feet with no problems at all . I reckon the latter requires a lot more than 1000 lbs to achieve.
JC,
   / 3 point lift capacity #4
If I recall, Ford 1000.1100 and 1200 were one chassis and 1300, 1500 and 1700 being one step up. I don't think that a 1000 has anywhere near the 3 pt hitch lift capacity that a 1700 does. I had a 1710 and I recall the 1000 being tiny relative to it.
Andy
   / 3 point lift capacity #5
In my Ford 1000 series service manual I found the lift capacity for the 1100 listed in the repair section for the hydraulics. The 1100 has a lift capicity of 881 lbs in lower top link. I don't know why that makes a difference. I hope this helps
Bill
   / 3 point lift capacity #6
Andy
The 1000 should be ( IIRC ) a different chassie... they were only built about 3ys.. 73-76? and were 25 engine hpand weighed about 2400# ( IE.. 8n sized machines )
the 1100/1200 were smaller riding lawnmower sized machines with 13 engine hp / 1200# and 16 engine hp / about 1300# respectively ( 4wd may add some weight there.. )
Completely different class of machine... the 11xx and 12xx are like riding lawnmowers.. the 1000 was more of a traditional scut sized tractor.
Other ford / NH tractors in that size, as pointed out have lifts inthe 1000-1800# area.. My 1920 ( slightly larger tractor.. had something like 1890# lift rating ). A ford hundred series tractor had at least 1200# lift, with an N doing near 1000# if you chained the front axle to the ground and the in-pump relief wasn't weak.
Soundguy
Thanks for the replies. I checked the owners and repair manuals, the relief valve is set at 1425 psi but thats all I could find. I was just curious but as Soundguy and others pointed out, it should be at least 1000lbs. The 770 loader is listed at 700 lbs.
   / 3 point lift capacity #8
Not sure if the picture appears but I have a 1200 that I recently picked up, great little machine, I pick up just under a face cord of hardwood with a 3 PT pallet forks. I want to start a thread on my new purchase but have not had time to get the picks and stuff together.
   / 3 point lift capacity #9
For all you new owners I have this Ford 1000 Series Specification brocher from 1981 with the all kinds of specifications which includes the following information:
Hydrolic lift capacity at link ends, pounds.
1110 = 881
1210 = 881
1310 = 1432
1510 = 1432
1710 = 3813
1910 = 3813
This is official ford information and the brochure contains much more including:
Engines:
Drive components:
PTO:
Capacities:
Deminsions:
I will be happy to share any of this information to all those that need it. Ray
I noticed the 1000 and 1600 are shown as being similar to each other as they are covered in one of the repair manuals that I have. Thats quite a lift capacity for the 1710 and 1910.
2013 JLG 8K TELEHANDLER (A58214)
2013 JLG 8K...
2020 Topcat 48" Hydraulic Articulating Skid Steer Cutter, S/N BORC20120101, Asset# 69 (A59076)
2020 Topcat 48"...
Quick Attach Bale Spear (A57454)
Quick Attach Bale...
JOHN DEERE 9570 RX (A58214)
JOHN DEERE 9570 RX...
2012 Ford F-550 (A55973)
2012 Ford F-550...
2010 Toro Workman MD Utility Cart (A55973)
2010 Toro Workman...
