3 point landscapeing rake
/ 3 point landscapeing rake #1
deerseeker001
Super Member
Central wisconsin
International 2500a with Loader
this is my new project,landscapeing rake.took cutting edge off and took .3/8 steel and welded rebar.i just need it for small rocks.
/ 3 point landscapeing rake #2
Looks like that'll work, can you reverse it and have a straight edge too?
when iam done with the landscapeing all i have to do is unbolt it and put my cutting edge back on and i have my backblade back.
/ 3 point landscapeing rake #4
Cool, the only issue is rebar does not provide spring action and easily bent. It will work if you are moving crushed rock and don't hit a big rock. It is cheap and easy to replace tines(aka, rebar). Good idea:) I do use rebar alot to make stuff.
JC,
thanks,i have the area where the new lawn is going in quack dug and there is alot of little rock so i am going to take the third arm on the 3 point and set it so we are just skimming the surface to drag the small stones in a pile and pick up with the fel.update i used it for the first time today and it beat my expectations,it worked great.
update i tried the lawn rake today and it beat my expectations,did a fantastic job.i did hit some big rocks and bent a few but will straighten out with a little heat.
/ 3 point landscapeing rake #7
good. heat will soften the metal even more, may be quenching with water will harden it some. you can use a piece of 3/4" pipe inserted over the rebar to bend it back.
JC,
yes the 3/8 steel plate unbolts and put your cutting edge back on and you ready to go
/ 3 point landscapeing rake #9
Nicely done ! Looks like a handy device to have around. I often wondered if somebody manufactured a Rake/Rear Blade interchangeable combo unit. Great idea.
/ 3 point landscapeing rake #11
They do. I think landpride and woods both offered it at one time.
The problem is, when looking at a blade or rake, the biggest expense in mfg'ing is the blade or the rake, NOT the 3PH frame. So it probabally doesnt cost much more to just have two seperate units instead of a combo that is probabally a little more difficult to change than the simple 3PH.
/ 3 point landscapeing rake #12
What you said makes good sense and is no doubt the reason. For a lot of people including me, storage space under roof is a premium and having something interchangable makes sense but may not be practicle. Appreciate the comments. Have a great weekend!
/ 3 point landscapeing rake #13
Brewdog, check out Land Pride for a nice RB/Landscaping rake.
GGB
/ 3 point landscapeing rake #14
/ 3 point landscapeing rake #15
That's a neat idea for what you are using it for. I've had times where the flexibility of the rake tines really came in handy though, like when hitting things that resist moving. But like you said, you can just bend the rebar back if you hit something that won't move.
i have about 45.00 bucks stuck into it beats 400-500$ for a boughten lawn rake.it did a great job.just your time invested which was one morning.
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2010 Kenworth T3 Class 7 Flatbed, 4x2, w Tuck-Under Liftgate (A63689)
2010 Kenworth T3...
2018 Lincoln MKT Town Car AWD SUV (A61574)
2018 Lincoln MKT...
2015 A and A Melters A-110 Towable Hot Rubber Melter (A61572)
2015 A and A...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
