3 point hydraulics
   / 3 point hydraulics #1
rj's barn
I have a good one here. Its a 'bishi 2350 with a weak 3pt hitch. It just suddenly quit when i was moving dirt with a box blade. Killing the engine and starting it back worked at first and it had full lift power. Soon after that it would barely lift the empty hitch bars. I have cleaned out my control valve twice and adjusted it back to factory spec with no good luck. I also blew compressed air through every passage I could find that relates to the rear hitch and it all flows air like its clear. The FEL will still pick up the back of my truck so I know its not a pump or a final bypass issue. And i'm stumped. Can anybody point me in a direction? Gracias!
   / 3 point hydraulics #2
if you can describe the connections from the fel controls to the 3 point hitch in more detail it may help.if you are using the power beyond hose to send fluid to the 3 point u have to make sure there is good fluid flow.the lift cylinder could have a busted seal.the bypass safety valve could be broken.
I got it figured out. the spring in the end of line bypass for the 3 pt got weak. I shimmed it with some small washers and got it working. Thank ya though.
2005 Ford E-350 Cargo Van (A51692)
2005 Ford E-350...
Unused 2025 GIYI KH72 72in 4-Way Hydraulic Bucket Skid Steer Attachment (A51691)
Unused 2025 GIYI...
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53473)
2016 Ford F350 -...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
1266 (A50490)
1266 (A50490)
