3 point hydraulics Max26
   / 3 point hydraulics Max26 #1
vietvetharry
Upstate SC
Mahindra Max26XL Shuttle, Montana C4864
I had to remove the FEL to weld the support frame that broke. I looped the two hydraulic lines that were going to the FEL controller thinking that would keep the system closed, but now the 3 point will not lift. Do I need to bleed the lines or do I have to reroute the hydraulics differently? HELP please.
   / 3 point hydraulics Max26 #2
Hi Harry, there should be 4 hydraulic connections to the loader and disconnecting those should be the only thing 'ya have to do.....
Joe H.
Thanks Joe, but I also had to remove the frame to have it welded and that required me to disconnect the joyshick and hydraulic lines. I capped the three connections on the hydraulic block that went to the FEL and the one that went to the rear for the backhoe. The 3 point still will not lift except by hand.
   / 3 point hydraulics Max26 #4
Ok Harry, I got it now!! Have to draw me a picture..lolol. Guess I can't help in this regard. Hope 'ya find the cure!
Joe H.
   / 3 point hydraulics Max26 #5
Can you post photo of what broke?
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2008 STEPHENS...
2021 FREIGHTLINER 126 SLEEPER TRUCK (A51222)
2021 FREIGHTLINER...
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A51039)
2020 Massey...
Ford Super Duty Pickup Truck Bed (A49461)
Ford Super Duty...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
