3 point hitch
/ 3 point hitch #1
Patrick553
1715 Ford
My three point hitch on Ford 1715 won't operate. Fluid levels are fine, front loader operates and there is hydraulic fluid to the control valve. Any ideas what else to check?
/ 3 point hitch #2
Welcome to TBN.
Does the hitch not go up?
Or does the hitch not go down?
Bruce
/ 3 point hitch #3
Welcome to TBN.
Have you check all points connections something may have loosen also debris build up.
/ 3 point hitch
Welcome to TBN.
Bruce
Neither direction, stripped it down to the KBM valve body. Can't see a thing wrong, o-rings look fine, linkage all operating, fluid to the valve. The lift cylinder seal is dry on the case side.
/ 3 point hitch
Welcome to TBN.
No leaks, recently serviced by a New Holland dealer. Fluid levels fine, front loader works so it's not a pump issue. Broke it down to the control valve, don't see a thing wrong externally
/ 3 point hitch #6
Linkage disconnected somewhere?
Bruce
/ 3 point hitch
Welcome to TBN.
Bruce
Bruce
Bruce
Nope, no fluid getting to the lift cylinder. Got to be a problem in the control valve. Bypass somewhere. Could it be air locked?
/ 3 point hitch #8
I have the same issue with 3 point trying to lift . did poster ever figure out problem ?
/ 3 point hitch #9
Do you have rear remote(s)? If so, is it in the neutral position? On some tractors the pressure feed to the 3-point goes through the rear remote valve, and if the rear remote valve is not in the center (neutral) position, no flow gets to the 3-point control valve. This is more common if your rear remote is the detent style installed with backhoes.
/ 3 point hitch #10
No remote s three point quit as soon as I changed the loader controller. All I did was removed hoses from old to new controller. Three point will raise as long as there is no weight on arms and they will stay up .
/ 3 point hitch #11
Does the new replacement loader valve have power beyond function active. Some valves require a special sleeve type fitting others require installing a plug. Without this feature your 3 point won’t work.
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2020 Ford F-150...
2006 Dodge Charger Sedan (A64557)
2006 Dodge Charger...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
8ft Fork Extensions (A64553)
8ft Fork...
2002 MITSUBISHI FG40K FORKLIFT (A66091)
2002 MITSUBISHI...
2023 KUBOTA SVL97-2 SKID STEER (A65053)
2023 KUBOTA...
