3-point hitch
/ 3-point hitch #1
Oliver 770
Newport,Nova Scotia
Oliver770, 1964 MF Backhoe
I,m fixing up an Oliver 770 wheatland tractor and at the present time doesnt have any hyd. on it. Just a draw bar. Is there anyway I can install hyd. 3-point hitch on this tractor,if so any info would be appreciated.Thanks
Scotty
/ 3-point hitch #2
The answer could be yes, depending on how much agro-engineering you want to do. Central Tractor (long since bankrupt) used to sell a bolt on 3pt for farmall H's and M's. So yes you can make something, but not to sure about buying something that you can just bolt on.
With enough time and money, almost anything can be done.
If you are just looking for a tractor with a 3pt, you may be able to buy another tractor with one for what it will cost you do get one set up on the oliver.
/ 3-point hitch #3
saginow tractor works makes a bolt on 3pt hitch, hd.. for allis, old jd's, farmalls.. etc.
all you need is a hyd source.. don't have to be much mor ethan a couple gpm or much over 1500 psi to make a real good hitch.
a pto pump with extender shaft world work.. though be spendy.
I'd check into an engine pump.. etc.
heck.. for limited use, a 12v electric over hyd ready pack could be tucked under a running board and handle a low volume 3pt lift.... or adapt a PS pump.. etc.. lots of possibilities..
soundguy
/ 3-point hitch #4
Go to YT MAG and post on the oliver board. Can't you put a factory hydra -electric hydraulic unit on it? You can still find these used. Why butcher? I'm not 100% sure if you can add a PT or hydra hitch to a wheatland, but the guys on ytmag.com will know, and no doubt can supply pics also. Where are you located?
/ 3-point hitch #5
Here is an advertisement i found on the internet. They have 3 different models to choose from one is as low as $695.00
Phone number is in the advertisement. Hope this helps.
Don
3-Point Hitch Conversion Kit
Our Price: $1,414.00
Fits Oliver 66, 77, 88, Super 66, Super 77, 660, 770
Category 1 or 2
Requires one hydraulic cylinder
Use original swinging drawbar
Ruggedly constructed
Screw-type Top Link with plenty of adjustment
Heavy duty ball-type sockets
Adjustment for various lifting heights
Turnbuckle lift arm adjustment on both sides
Lock nuts for positive adjustment hold
Instruction manual and repair parts list included
Must ship via LTL freight carrier due to size
Please call 1-866-609-1260 for a freight quote
All new, rebuilt and used tractor parts have a 1-year
/ 3-point hitch #6
the one I mentioned is HALF that price.. saginow...
oliver3pointconversionkit - www
770 is listed. 795$.. etc.
very HD 3pt lift components. I looked at them for a farmall H I was considering buying.
soundguy
/ 3-point hitch #7
You can find an Oliver Power Traction hitch or Hydra Hitch used for less than that. The PT hitch is MORE than twice as heavy as any aftermarket Oliver 3pt. Here's a pic of one of mine if it helps. It is the Power traction hitch, not the Hydra....
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
2015 Caterpillar 420F (A64126)
2015 Caterpillar...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
2002 CATERPILLAR 963C CRAWLER LOADER (A65053)
2002 CATERPILLAR...
