3 Point hitch
/ 3 Point hitch #1
B3300SU
Im sure there are many out there with the quick hitch couplers for implements. Im thinking of buying a set. Any advice or input on which ones would be great.
Thanks
/ 3 Point hitch #2
The ones at Harbor Freight are certainly reasonably priced, but I have no idea how good they are. There is a thread around here on Harbor Freight tools that don't suck, might look there.
/ 3 Point hitch #3
TSC has Speedco which I have for my B3200TLB, looks just link Land Pride's except $100. cheaper.
DevilDog
/ 3 Point hitch #4
I have a Land Pride and am extremely happy with it. It sure beats trying to wrestle an implement around to line everything up. Just back up to it, raise the 3 point and flip down the two levers.
The only drawback I can see is if the spacing doesn't match a particular implement. So far, everything I have fits perfectly. Well, I did have to reconfigure the bolts on top of my mower, but it was simply a matter of removing one of the bolts just below the slot where the top link goes.
I haven't heard anyone discussing a Harbor Freight quick hitch, but unless you are really rough with it, I would think it would work just fine.
/ 3 Point hitch #5
Since no one has mentioned it yet, I will.
Go to the Attachments forum on TBN and check out the sticky at top that deals with Pat's Quick Change system. It is the most adaptable if any of your implements do not have a standard 3PH hook up pattern.
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
Schuler Feed Wagon (A66408)
Schuler Feed Wagon...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
Landhonor ATS-RT15R Mini Excavator (A66285)
Landhonor...
2007 International 7300 Digger Derrick Crane Truck, VIN # 1HTWBAAN77J422035 (A65563)
2007 International...
Hydraulic Auger Mini Skid Steer Attachment (A64553)
Hydraulic Auger...
