3 Point hitch
/ 3 Point hitch #1
B3300SU
Im sure there are many out there with the quick hitch couplers for implements. Im thinking of buying a set. Any advice or input on which ones would be great.
/ 3 Point hitch #2
The ones at Harbor Freight are certainly reasonably priced, but I have no idea how good they are. There is a thread around here on Harbor Freight tools that don't suck, might look there.
/ 3 Point hitch #3
TSC has Speedco which I have for my B3200TLB, looks just link Land Pride's except $100. cheaper.
DevilDog
/ 3 Point hitch #4
I have a Land Pride and am extremely happy with it. It sure beats trying to wrestle an implement around to line everything up. Just back up to it, raise the 3 point and flip down the two levers.
The only drawback I can see is if the spacing doesn't match a particular implement. So far, everything I have fits perfectly. Well, I did have to reconfigure the bolts on top of my mower, but it was simply a matter of removing one of the bolts just below the slot where the top link goes.
I haven't heard anyone discussing a Harbor Freight quick hitch, but unless you are really rough with it, I would think it would work just fine.
/ 3 Point hitch #5
Since no one has mentioned it yet, I will.
Go to the Attachments forum on TBN and check out the sticky at top that deals with Pat's Quick Change system. It is the most adaptable if any of your implements do not have a standard 3PH hook up pattern.
Wolverine MCB-11-48W Mini Skid Steer Bucket (A62679)
Wolverine...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
ATS 40 Gallon 2 Stage Air Compressor (A62679)
ATS 40 Gallon 2...
SRECO Flexible Sewer Cleaning System (A65579)
SRECO Flexible...
2005 GMC TOPKICK C6500 TESTING UNIT (A65643)
2005 GMC TOPKICK...
