3 point Hitch won't go all the way down
   / 3 point Hitch won't go all the way down #1
Jeje
Mahindra 2615
Hi Everyone,
I have a mahindra 2615 that has no draft control installed. I rototilled my field last year and it was barely tilling 6" down. This year, my attachment does not even touch the ground. The lever operates well, 3PH goes up and down, but it doesn't go down enough. I know most tractor have a draft control that takes care of that but mine is not equipped with it. I played with the knowb under my seat, the one that controls the speed of the 3PH, but it doesn't seem to help. What I am missing, any suggestions would be much appreciated!
   / 3 point Hitch won't go all the way down #2
Welcome to TBN.
This may help you or someone else.
Bruce
Thanks for that Bruce, it is helpful to have this manual and I didn't know it was the same as a club cadet.
Still need help[ with my issue if someone thinks of something...
   / 3 point Hitch won't go all the way down #4
I had a three point which wouldn't go down all the way. I found a stop clamp on the three point control. After I moved it to the end of travel I could move the three point lever further and the hitch complied by going down further.
   / 3 point Hitch won't go all the way down #5
Welcome to TBN
Can you post a photo of your tractors rockshaft(3pt) control handle in the lowered position? I'm curious if your tractors 3pt linkage has a feedback rod similar to my Kubota
Here are some pictures of the rockshaft in lower position. There seems to be a feedback rod on one arm, I have never adjusted this rod before, curious to hear what your experience has been with this part.
Welcome to TBN
Thanks for the welcome! Here are some pictures of the rockshaft in lower position. There seems to be a feedback rod on one arm, I have never adjusted this rod before, curious to hear what your experience has been with this part.
   / 3 point Hitch won't go all the way down #7
Have you tried it with the PTO shaft disconnected or ensured your PTO shaft moves feely throughout it's full range of motion?
   / 3 point Hitch won't go all the way down #8
You're manual should tell you where that rod should be adjusted at, it could be related.
Thanks for your reply, all my stop clamps are locked on both extremities (see picture above) so it is not the issue.
   / 3 point Hitch won't go all the way down #10
If it were me, before messing with anything on the tractor, I'd take the attachment off the 3 pt and then see if the arms go down further with nothing attached. That would eliminate that at least. You would have to push down on the arms after the leer is in the lowered position.
1998 Pierce Enclosed Cab Fire Truck (A50860)
1998 Pierce...
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A51039)
Kubota BX2680...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
