3 Point Hitch Slow
/ 3 Point Hitch Slow #1
granddadtc
Waskom,TX
Ford 1700
Ford 1700 3 point hitch lifts as usual, fast and strong. The problem is going back down, i can drink a cup of coffee waiting! Anyone have a tip for me? :eek:
Thanks!
/ 3 Point Hitch Slow #2
Check to see if it has an adjustment knob or lever somewhere in the 3 point area.
It might be under the seat or on the top of the 3 point .
With no wieght on the 3 point it probably will be slow.
I am not familiar with your tractor but my kubota has a knob that adjusts the fall speed.
/ 3 Point Hitch Slow #3
My Mahindra also has a know below the front of the seat. It controls down speed of the 3Pt arms. You probably have one too.
Ok, you guys are genius! My valve was closed. It is VERY easy to turn, almost to the point i belive vibration could close it. I'll see if there is a lock down nut or something to tighten up the adjustment knob.
Thanks for the info, feeling dumber than usual,
Tim
/ 3 Point Hitch Slow #5
On some of the older fords, the draft control can interfer with the link arm drop rate - try adjusting the draft leaver if fitted... Same thing happens on our NH if the draft is set too high.
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
(2) Denman Tires w/Rims (A64127)
(2) Denman Tires...
2017 Mack Semi (A64047)
2017 Mack Semi...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
2018 CAT 259D Skid Steer (A62613)
2018 CAT 259D Skid...
