3 point hitch on 4530 sluggish
   / 3 point hitch on 4530 sluggish #1
FarmKuro
I have a 4530, and pretty much since the day i bought it, the 3 point seems to hang in the up position and you can't lower the arms. The dealer took it in and couldn't find anything wrong. The problem is now worse, I have middle buster on the tractor and can't get it down. Any similar problems or ideas.
   / 3 point hitch on 4530 sluggish #2
I had the same problem with my bobcat ct440. The problem was a stuck valve on the three point hitch lowering/lock valve. I took the valve apart and freed it up, and now it seems to work fine. I don't know if you have a similar valve on your tractor? Hope this helps.
   / 3 point hitch on 4530 sluggish #3
I had the same problem with my 2810 HST. The valve that controls the speed of drop and it shuts off the flow of oil so it will not settle when in transport closed it self off. Dont really know a good name worth repeating for it but. . .it should be directly under the seat on the floor. Only stipulation is don't, DON'T!TURN IT ALL THE WAY OUT. My Kioti has a tendency of shutting itself off too.
   / 3 point hitch on 4530 sluggish #4
My guess is that the "Hitch lowering speed adjustment knob" needs to be adjusted properly.
2007 John Deere CT332 Skidloader (RIDE AND DRIVE) (A50774)
2007 John Deere...
Parker 2500 Gravity Wagon W/Auger (A50774)
Parker 2500...
2002 International 9200i Truck (A52748)
2002 International...
2013 Nissan Juke SUV (A50324)
2013 Nissan Juke...
2014 Kia Sorento SUV (A50324)
2014 Kia Sorento...
2004 Ford F250 (A50515)
2004 Ford F250...
