I have two questions that I could use some help on.
First, I have a John Deere 1050 that has a backhoe and FEL. Recently I took the backhoe off, for the first time, to put on a brush hog. The problem is that I cannot get the 3-point hitch to raise or lower. I have looked through the manual and I think I am doing everything correct. Hoses from the backhoe, when it was removed, have been connected together. Hydraulic stop valve is open. I have tried raising the hitch with the draft sensing lever in "Position Control" and "Draft Control". I have adjusted the "speed of drop lever". The FEL works fine and the backhoe worked fine.
Second question. How much weight could my FEL lift. I don't have any paper work on it and have looked through the tractor manual and can't find anything. I am looking at getting some large precast retaining wall blocks that would be set using my tractor.
Any help would be appreciated. Thanks. I am definetly a tractor rookie so go easy on me.
