3 point hitch not high enough
   / 3 point hitch not high enough #1
zeke83
Little falls, NY
Cub Cadet GT2542
I have a sub compact cub cadet 5264d. I borrowed a york rake to do my gravel driveway. The only problem is I can only get the rake tines about 3 inches off the ground when fully raised. I can adjust the top arm to raise it off the ground more, but then it's not level when down. This tractor is new to me and I plan to buy implements for it, but this looks to be an issue I need to solve.
Are there fast hitches or something that can be used change the height of the connection points?
Thanks
   / 3 point hitch not high enough #3
This is a problem with sub compacts with some attachments. A quick hitch helps because it extends the reach 4 or 5 inchs which means it has a little more leverage. Rakes, blades are a problem with getting them high enough off the ground and still be able to use them. They do make some " sub compact" attachments, TS has a rake designed for the sub.
They are currently 18" long. When I put the 3 point hitch all the way down with nothing attched, the lower arms are only 2 inches off the ground. All the way up, they are 24" off the ground
   / 3 point hitch not high enough #5
Are they threaded so that you can screw them in more and make them effectively "shorter"?
It's likely one is fixed length (with threads only at one end?), and the other has additional threads and a "turnbuckle" so it's length can be adjusted (to level (or angle) attachments). The adjustable one likely adjusts to a shorter length than the fixed one. It may be possible to replace the fixed length one with an adjustable one so that both their lengths can be minimalized
Only one side is adjustable. I think I may need to try and find some shorter link arms.
   / 3 point hitch not high enough #7
There is only so much adjustments to the 3-point linkage that you can make and there is size restrictions to 3-point hitch implements that a sub-compact tractor can use. Both of which have been pointed out already. Good that you are learning now before actually purchasing implements that aren't suited for your sub-compact tractor.
You can lengthen the lower arms a few inches with a quick hitch attachment but you also loose a little leverage and lifting power, however slight.
Like you are thinking, shorter lifting links may help you the best. Maybe find another adjustable link arm to replace the non-adjustable lifting link.
   / 3 point hitch not high enough #8
the lower lift arms, were they connect to tractor. there might be another hole in the lower lift arms to attach to tractor.
the turn buckles (2 long eye bolt screws, with a long nut), and then another that is fixed length connecting to lower lift arms, some times were these connect to lower lift arms you have another hole you can connect to within the lower lift arms.
the top link were it connects to tractor, sometimes the tractor has an extra hole or two you can connect top link to.
some times the implement itself has 2 holes were top link connects to it.
some times the implement has 2 or more bolts per say that the lower lift arms attach to it.
pats easy hitch, might be more useful.
upside down u shape quick hitches, you may need to modify implements to work with them (as in cut and re weld)
telescopic and lower lift arms you might be able to buy some place that might be a bit longer.
make sure you have your "check chains" the fit between lower lift arms and generally attach around the PTO shaft on rear of tractor
make sure you have your "sway bar/chains" they fit on the outside of lower lift arms and back to tractor.
both of above help stiffen up and protect the 3pt hitch within reason from side way forces.
3pt hitches have all sort of bars/linkages and can get confusing at times, you might try posting a couple pictures with implement hooked up showing implement and then showing the connection points of the 3pt hitch at tractor and at the implement.
   / 3 point hitch not high enough #9
It's probably a Limited Cat 1. My John Deere 2210 was also. It's a Cat 1 hitch but does not have the full height of a standard Cat 1. I also had a quick hitch on it. The quick hitches don't change how high you can lift the implements.
   / 3 point hitch not high enough #10
The E-Z hitch advertised at carterandsonsllc.com could raise the attachment height of the lift arm a couple of inches. They have a little different design than Pat's and some others have.
19010 (A55851)
19010 (A55851)
flooring (A55758)
flooring (A55758)
Hr:2185.1 jihn Deere (A56857)
Hr:2185.1 jihn...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
