3-point hitch hitting back tires: PLEASE HELP!
   / 3-point hitch hitting back tires: PLEASE HELP! #31
Thats a Cat 2 mower, with Cat 1 pins on a Cat 1 hitch. You need to turn lower pins around to point inwards.
If you need to use it on a Cat 2 hitch too, they make double pins that leave a cat 1 on the inside and Cat 2 pins outside.
You won't be able to keep the sway so tight that it won't hit your tires without swapping the pins.
Thanks guys for all the good suggestions. I'll add "washer-bushings" to the stab arm shackles, Cut off those rusted bolts on the hog frame arms and get some stainless bolts and secure those hog arms.....or at least make them much tighter. Get sleeves to stop that upper attachment "pinch" AND turn the lower arm pins inward. That ought to greatly reduce my swaying hog.
Thanks again. You guys are great.....:thumbsup:
   / 3-point hitch hitting back tires: PLEASE HELP! #32
why will the rotary cutter hit rear tires when raised up
   / 3-point hitch hitting back tires: PLEASE HELP! #33
Because the top link needs to be shortened or put in a different hole so that it stays at the same angle as it lifts up?
Aaron Z
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
2005 Volvo VNL Truck, VIN # 4V4N19TGX5N374968 (A57453)
2005 Volvo VNL...
2001 Freightliner FL80 Bucket Truck, VIN # 1FVDBXAK01HG77631 (A57453)
2001 Freightliner...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2009 Ford Econoline Wagon Van, 101,671 Miles (A56438)
2009 Ford...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
