Rear Blade 3 Point Hitch and Rear Blade Questions
   / 3 Point Hitch and Rear Blade Questions #11
See if this makes any sense to anybody. When you rotate the blade to angle it, it pivots around an axis. If this axis is dead plumb, then you can change the angle and still keep the blade parallel to the ground.
So if you can adjust the top link and the 3 point hitch to make the axis plumb while the blade is on the ground, you should be able to set any angle you want without one end digging in or lifting up. True?
Maybe you could hold a small level vertically on two sides of the pivot to check for plumb and get your adjustments figured out
Tom in Michigan
   / 3 Point Hitch and Rear Blade Questions #12
That's the technical explanation of my post above!
   / 3 Point Hitch and Rear Blade Questions #13
</font><font color="blue" class="small">( That's the technical explanation of my post above! )</font>
I read your post again and you're totally right. I think your method for adjusting the links is probably a lot better than my suggestion for using a level.
Tom in Mich
   / 3 Point Hitch and Rear Blade Questions #14
</font><font color="blue" class="small">( </font><font color="blueclass=small">( That's the technical explanation of my post above! )</font>
Tom in Mich
)</font>
Both are right, one is textbook, one is out in the field modification... /forums/images/graemlins/wink.gif
--->Paul
   / 3 Point Hitch and Rear Blade Questions #15
KUDOs to TobyH! I have been having fits trying to get my rear blade, a 5' Frontier to plow snow without gouging my gravel driveway. I installed skid shoes and then had to elevate them 2" below the moldboard in order to keep the blade from jitterbugging on the stones. After adjusting the blade using your method, I was able to lower the skid shoes to 1/2" below the board and voila, I can now plow snow right down to the gravel bed.
Thanks,
Cal
(NEW) 2022 Greenworks CU400W Commercial Work Utility Vehicle (A55314)
(NEW) 2022...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
Kubota RTV-X900 4x4 Diesel Utility Cart (A55851)
Kubota RTV-X900...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
2016 FREIGHTLINER CASCADIA DAYCAB (A53843)
2016 FREIGHTLINER...
