Rear Blade 3 Point Hitch and Rear Blade Questions
   / 3 Point Hitch and Rear Blade Questions #11
See if this makes any sense to anybody. When you rotate the blade to angle it, it pivots around an axis. If this axis is dead plumb, then you can change the angle and still keep the blade parallel to the ground.
So if you can adjust the top link and the 3 point hitch to make the axis plumb while the blade is on the ground, you should be able to set any angle you want without one end digging in or lifting up. True?
Maybe you could hold a small level vertically on two sides of the pivot to check for plumb and get your adjustments figured out
Tom in Michigan
   / 3 Point Hitch and Rear Blade Questions #12
That's the technical explanation of my post above!
   / 3 Point Hitch and Rear Blade Questions #13
</font><font color="blue" class="small">( That's the technical explanation of my post above! )</font>
I read your post again and you're totally right. I think your method for adjusting the links is probably a lot better than my suggestion for using a level.
Tom in Mich
   / 3 Point Hitch and Rear Blade Questions #14
</font><font color="blue" class="small">( </font><font color="blueclass=small">( That's the technical explanation of my post above! )</font>
Tom in Mich
)</font>
Both are right, one is textbook, one is out in the field modification... /forums/images/graemlins/wink.gif
--->Paul
   / 3 Point Hitch and Rear Blade Questions #15
KUDOs to TobyH! I have been having fits trying to get my rear blade, a 5' Frontier to plow snow without gouging my gravel driveway. I installed skid shoes and then had to elevate them 2" below the moldboard in order to keep the blade from jitterbugging on the stones. After adjusting the blade using your method, I was able to lower the skid shoes to 1/2" below the board and voila, I can now plow snow right down to the gravel bed.
Thanks,
Cal
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A53421)
2025 MS380R Mini...
Toro Mower (A50324)
Toro Mower (A50324)
1994 Generac Olympian 3054 125kVA 3-Phase Diesel Generator (A55851)
1994 Generac...
