3 point has no down pressure
   / 3 point has no down pressure #1
Coloradokid
JD 4710
My JD 4710 has no downward pressure on the 3 point lift arms, with or without an implement attached. However, they do lower overnight with an implement attached. Any suggestions?
   / 3 point has no down pressure #2
Turn the rate knob
Thanks. I'll try that.
   / 3 point has no down pressure #5
Been on a lot of tractors in my time. NONE have had down pressure on the 3 point hitch arms. They could lift only.
   / 3 point has no down pressure #6
Believe it or not but Belarus had down pressure. At least on the ones I saw.
   / 3 point has no down pressure #7
@Coloradokid , As mentioned several times, the 3PH on your tractor does not have "down pressure", but can you describe your issue differently in case we are not under standing?
   / 3 point has no down pressure #8
There is a 3Ph down pressure kit available for 4R series tractors. It might be backwards compatible to the 4720s?
2020 CASE IH 110N LOT IDENTIFIER 207 (A53084)
2020 CASE IH 110N...
UNUSEDX-STAR 72" QUICK ATTACH GRAVEL LEVELER (A51247)
UNUSEDX-STAR 72"...
FRONTIER AH11G LOT IDENTIFIER 100 (A53084)
FRONTIER AH11G LOT...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2017 Wanco WSDT Towable Compact Radar-Speed Trailer (A52377)
2017 Wanco WSDT...
2020 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A53426)
2020 KENWORTH T680...
