3 Point Grapple Claw
/ 3 Point Grapple Claw #1
imabass
Pawnee, OK
JD 3020 Propane
Made this to attach to my boom pole for picking up logs, brush, and other junk. This speeds up the process since I don稚 have to get off the tractor and hookup via chain to what I want to haul off. My material cost was about $400.
Materials listing:
1 36" x 20" x 3/8" air or propane tank $50
8 1.5" x 0.243" DOM tubing for hinge and pin bushings. $52
10 1 solid steel bar for hinge pins and hydraulic mount pins $40
~80# scrap drop 3/8 plate steel $50
3- Heavy duty D rings $15
10 5/16 chain $15
2 Chain clevis $5
2 2x8 hydraulic cylinders $120
2- 3/8 x 2 hydraulic hose $12
2- 3/8 hydraulic T fittings $10
2- 10' 1/2" hydraulic hoses $20
I started by making the support box on top of the air tank. I then made the tower that the hydraulic rams attach to. I made my hydraulic cylinder mounting plates and attached them to the tank. I then cut the top of the tank (approx. 1.5 wide) to mount the hinges. I inserted the hinge pins in the DOM tubing in order to make sure they properly line up. I then welded the hinges in place. Next I torch cut the teeth in the side and bottom of the tank and where it was completely split in 3 pieces (top support box, left and right claw). Plumbed up the hydraulic hoses and attached to boom pole.
So far it is working as planned. I do need to replace one hydraulic hose with a longer one as when the claw if fully opened, it is stretching the lower hose.
Tractor 3 point hydraulic grapple claw - YouTube
/ 3 Point Grapple Claw #4
Just saw this on YouTube. Cool idea
/ 3 Point Grapple Claw #5
thats totally awesome. great job
66in Bucket Skid Steer Attachment (A61572)
66in Bucket Skid...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
2004 INTERNATIONAL RA027 4X2 S/A DAY CAB TRACTOR (A59911)
2004 INTERNATIONAL...
2016 Great Dane 50ft. T/A Refrigerated Van Reefer Trailer (A61573)
2016 Great Dane...
Willmar 4550 Wrangler Articulating Loader (A63689)
Willmar 4550...
