3 Point Grapple Claw
/ 3 Point Grapple Claw #1
imabass
Pawnee, OK
JD 3020 Propane
Made this to attach to my boom pole for picking up logs, brush, and other junk. This speeds up the process since I don稚 have to get off the tractor and hookup via chain to what I want to haul off. My material cost was about $400.
Materials listing:
1 36" x 20" x 3/8" air or propane tank $50
8 1.5" x 0.243" DOM tubing for hinge and pin bushings. $52
10 1 solid steel bar for hinge pins and hydraulic mount pins $40
~80# scrap drop 3/8 plate steel $50
3- Heavy duty D rings $15
10 5/16 chain $15
2 Chain clevis $5
2 2x8 hydraulic cylinders $120
2- 3/8 x 2 hydraulic hose $12
2- 3/8 hydraulic T fittings $10
2- 10' 1/2" hydraulic hoses $20
I started by making the support box on top of the air tank. I then made the tower that the hydraulic rams attach to. I made my hydraulic cylinder mounting plates and attached them to the tank. I then cut the top of the tank (approx. 1.5 wide) to mount the hinges. I inserted the hinge pins in the DOM tubing in order to make sure they properly line up. I then welded the hinges in place. Next I torch cut the teeth in the side and bottom of the tank and where it was completely split in 3 pieces (top support box, left and right claw). Plumbed up the hydraulic hoses and attached to boom pole.
So far it is working as planned. I do need to replace one hydraulic hose with a longer one as when the claw if fully opened, it is stretching the lower hose.
Tractor 3 point hydraulic grapple claw - YouTube
/ 3 Point Grapple Claw #4
Just saw this on YouTube. Cool idea
/ 3 Point Grapple Claw #5
thats totally awesome. great job
2011 Chevrolet Express 2500 Cargo Van (A61573)
2011 Chevrolet...
2013 Chevrolet  Express 2500 (A62613)
2013 Chevrolet...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
UNUSED WOLVERINE RSB84-84" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
KUBOTA 72" PIN ON BUCKET (A64280)
KUBOTA 72" PIN ON...
