3 Point Grapple Claw
   / 3 Point Grapple Claw #1
imabass
Bronze Member
Pawnee, OK
JD 3020 Propane
Made this to attach to my boom pole for picking up logs, brush, and other junk. This speeds up the process since I don稚 have to get off the tractor and hookup via chain to what I want to haul off. My material cost was about $400.
Materials listing:
1 36" x 20" x 3/8" air or propane tank $50
8 1.5" x 0.243" DOM tubing for hinge and pin bushings. $52
10 1 solid steel bar for hinge pins and hydraulic mount pins $40
~80# scrap drop 3/8 plate steel $50
3- Heavy duty D rings $15
10 5/16 chain $15
2 Chain clevis $5
2 2x8 hydraulic cylinders $120
2- 3/8 x 2 hydraulic hose $12
2- 3/8 hydraulic T fittings $10
2- 10' 1/2" hydraulic hoses $20
I started by making the support box on top of the air tank. I then made the tower that the hydraulic rams attach to. I made my hydraulic cylinder mounting plates and attached them to the tank. I then cut the top of the tank (approx. 1.5 wide) to mount the hinges. I inserted the hinge pins in the DOM tubing in order to make sure they properly line up. I then welded the hinges in place. Next I torch cut the teeth in the side and bottom of the tank and where it was completely split in 3 pieces (top support box, left and right claw). Plumbed up the hydraulic hoses and attached to boom pole.
So far it is working as planned. I do need to replace one hydraulic hose with a longer one as when the claw if fully opened, it is stretching the lower hose.
Tractor 3 point hydraulic grapple claw - YouTube
   / 3 Point Grapple Claw #4
Just saw this on YouTube. Cool idea
   / 3 Point Grapple Claw #5
thats totally awesome. great job
Modine Shop Heater (A51573)
Modine Shop Heater...
2017 VOLVO VNL SLEEPER (A52577)
2017 VOLVO VNL...
FRONTIER GM1060E LOT NUMBER 249 (A53084)
FRONTIER GM1060E...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
48" Skid Steer Pallet Forks  (A52384)
48" Skid Steer...
