3 point auger help
/ 3 point auger help #11
As @LS Tractor Owner states, that tip is the problem. I have never seen an auger tip like that.
If you must use that particular auger you could try hand digging a small hole that would allow the cutting edges to get a better initial bite.
/ 3 point auger help #12
With mine when the soil is too dry on clay soil with thick vegetation I need to add weight to it in order for it to start digging.
/ 3 point auger help #13
I’ve seen and used two augers with tips like that. When the ground is soft they work, but they are not a desirable auger.
The only thing is that is the only type of tip that will work on that auger. To switch to the screw tip you need to buy a different auger.
2010 International 4400 S/A Day Cab Truck Tractor (A59230)
2010 International...
2019 FORD F-250 (INOPERABLE) (A60736)
2019 FORD F-250...
2022 North Star Pressure Washer (A60352)
2022 North Star...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
Kubota LX2620 (A53317)
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
