electrycmonk
- Joined
- Nov 6, 2018
- Messages
- 212
- Location
- Near Denton, TX
- Tractor
- Satoh 370 diesel & Cub Cadet 7260 Diesel 4WD standard
So This oddity gets its own thread.
Specific stats:
cub cadet 7260 4WD standard diesel
While cutting up the soil & removing it to put in a chicken coop with cement foundation..... the twin curled blade type tiller (don't remember the correct name for this old school tool) was cutting great. raise and lower wonderfully every time.... then all of a sudden, it wouldn't lift. I backed up the tractor thinking maybe its caught on a very big stone; then pulled the handle to full up and still no reaction at all. So, I disconnected the twin blade from the 3 point and spun around to use the bucket to move the twin blade out of the way.
Tried to cycle the engine to see if maybe the line had a pressure inducing clog on the 3 point internal stuff (my brain assuming this logical 1st thought). Still no response to the up & down of the control handle for the 3 point. Yet, the FEL still worked just fine.
Took lunch break and came in to research in forum and look at the pdf's i'd found here and online for the tractor..... didn't see anything the same. saw several stories of snow-bound issues based mostly on fluid dynamics.... Saw at least 2 on something about a internal pin and an allen head bolt(?) that a service tech didn't charge for the re-tear down to fix from the 1st go round....
So This evening about 8PM I went out to test the system...
FEL worked fine. 3 point still no response to control handle at all. So last thing to do was test to see if I could manually move the lower 3 point arms....
piece of cake! they lifted and lowered in my hands like the top link. yes they are heavy steel but, there was no detectable resistance (hydraulic or mechanical) to moving them (by hand) with the engine off and the control arm in either full up or full down position.
I thought of making a short (under 15 sec video) of this manual test but, don't think that's the best use of bandwidth out here in DSL-land. I could upload a couple pics tomorrow if that would help?
Specific stats:
