3 phase machines working on single phase ?
   / 3 phase machines working on single phase ? #1
bcarwell
Austin, Texas
Kabota 7500DT
I've seen several good buys on 3 phase welders and was wondering: can they be altered cost effectively to run on single phase, and if so, what's involved and what does that do to the performance specs ?
And is 3 phase just for commercial establishments, e.g. can the power company do something at the service drop to your house on a farm/ranch to give you 3 phase, or is this cost prohibitive or impractical if all you would use it for is a welder and maybe a few other things.
Bob
   / 3 phase machines working on single phase ? #2
I don't know about the converting part, but I can tell you that if you have 3 phase power nearby, you MIGHT get it at a big cost. You would probably have to buy a commercial acct with the power company. Power companies usually restrict 3 phase to commercially zoned areas. Expect a demand meter too instead of a regular meter.
If 3 phase is a mile or more away, you don't even want to know the price quote to bring it to your property. Hint: it will have at least 4 zeroes on the end.
   / 3 phase machines working on single phase ? #3
3 phase may not even be available in your area and it usually cost a lot for the service as well. I would think that most industrial transformer welders would have a set of taps on the inputs to allow for 460v 240v 220v single or 3 phase. Better check the tech specs with the mfg to be sure. Mine is a ESAB Heliarc 250 and it has several input settings. I run it on single 220v.
   / 3 phase machines working on single phase ? #4
You can use a rotary or static converter to obtain the 3 phase but you need to be sure that the converter can supply the power needed.
One other way to beat the high price of 3 phase from the power company is to use a generator. This is common for machine shops because a better finish can be obtained with 3 phase machines.
I have a 100kw 3 phase diesel generator but all my stuff is single phase, however if I come across some good deals that are more affordable because they are 3 phase I'm ready.
Or maybe I should just sell the generator, wonder how much it's worth?
   / 3 phase machines working on single phase ? #5
I run my home shop off a 3 phase rotary converter I made from an old 3 phase electric motor. Never had any problems running the Leblond Lathe or the Bridgeport Mill... never tried to run a 3 phase welder
One of the small medical clinics I work with had a 3 phase rotary converter powering their instrument sterilizer. The thing is NO ONE knew they had a converter. It quit running after running non-stop for more then 12 years with no maintenance.
The clinic priced 3 phase from the power company and found it would cost about 10 times the cost of replacing the converter just for the hook-up.
The new heavy-duty converter cost $1500, installed.
   / 3 phase machines working on single phase ? #7
It cost me over $8,000 to get the power company to run 3 phase to my garage and that was years ago. I wouldn't even want to guess what it's running now.
Like Ford960 said, a good "mobile" alternative is a 3 phase generator. I have one, not a huge 100K like his but a old military generator. It's a 10K I picked up for under $300 and will run every 3 phase machine I have.
   / 3 phase machines working on single phase ? #8
The short answer is no, it's not cost effective to buy and use 3 phase equipment when you don't already have it available. The small savings on the equipment don't even come close to the expense it will cost to make it work.
Eddie
   / 3 phase machines working on single phase ? #9
I too built my own rotary phase converter. It’s great because you find used industrial equipment like your welder, mills, lathes etc. that are great bargains because they are older 3 phase units. My converter is a 5hp unit and cost me about $80 to build with some parts scrounging. The output balance is within 5% between the phases from no load to full load. Works great.
   / 3 phase machines working on single phase ? #10
Running 3 phase equipment from single phase power happens all the time. You can do it several ways, depending on your needs for balanced power legs.
Static converters are the cheapest, rotary converters are what most people use, adding capacitors to balance the legs makes them better, and then you have the ultimate, which is "Phase Perfect" which are a little pricey, but do the job everyone wants, the way it should be. If your running 3 phase CNC equipment on single phase power, then that is the best way to go.
Back in the mid '90s, I asked one of the electricians how to do it, and he said you couldn't. I later found out how, and went and showed him a drawing and he said it wouldn't work. We went to the shop, tried it, it worked, but the voltage didn't make sense when read with a meter, but there it was, still working. He let it run for two days trying to burn the motor up from single-phasing, but it never did.
As mentioned, Practical Machinist has a good forum for phase converters.
David from jax
Welcome to the Manufacturing Forum: Transformers, Phase Converters and VFD
   / 3 phase machines working on single phase ? #11
I had to sign a contract with the power company stating I would buy $50,000.00 worth of power in 60 months before I could get 3phase.Rotary phase converters work well just make sure you are using one with enough hp.CNC machines will run on converters but I always dedicated a seperate converter for the 2 I was running at that time.A 2nd converter ran all conventional 3ph mills,saws and lathes.I did notice a web site a while back that is building convertors for CNC up to 100 or so hp.
   / 3 phase machines working on single phase ? #12
We built a new home in Dickinson, TX in the early 70's. We were on a street that ran behind the elementary school so that 3 phase lines were already on the poles. Since they had to hang a second transformer to give me 3 phase power I double the standard hook up.
We had 2 - 3 phase air conditioners on that house that ran for 25 years before they failed. I don't know if it helped but I reversed the rotation on the compressors about every two years. External corrosion finally did them in.
Vernon
   / 3 phase machines working on single phase ? #13
I own a small house in town that is zoned for light industrial use, with 3 phase on the pole at the corner of the property and they won't let me have 3 phase power until the house is removed or I agree to quit using the house for residential usage. We pay these people to provide a sevice and they service us as, and if they want...
David from jax
   / 3 phase machines working on single phase ? #14
3 phase welders can and will run good on rotary phase converters. Just remember that you CANNOT get more Amps out of these units than you are supplying to them!
A rotary 3 phase converter can be very simple. Simple as having a 3 phase motor with the motor input wires connected to the driven unit through a plug and starting the converter motor with a rope wound pull start! All of 5 minutes to put together. 1720 delta wound motors work the best and the most common to find cheap. Make sure that it is an industrial duty with ball bearing armature. Welders work best if run at the higher voltage setting and use a multi tap transformer with your rotary converter to balance the leg voltage. Welders will not work with the so called static converters.
Also those old Lincoln and Hobart DC bullet MG welders work flawlessly with a rotary phase unit. They are usually are as cheap to buy as the scrap is price to.
EF
   / 3 phase machines working on single phase ? #15
To check if you have three phase at the electric pole; see if you have 3 primary wires on top of the pole; If you do, you have three phase avaiable; if you have 1 primary wire on top of the pole feding the transformer, you only have single phase.
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
1968 Oliver Model 1950 2WD Tractor (A56438)
1968 Oliver Model...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
2013 CHEVROLET SILVERADO EXT CAB TRUCK (A60430)
2013 CHEVROLET...
