3 PH splitter questions
/ 3 PH splitter questions #11
I used a 3pt splitter with my BX22 and it worked just fine for my needs. I guess the cycle time was 10/12 seconds. For me, and just splitting for my own personal needs it was more than adequate. It is also nice not to maintain another motor. If I were splitting for commercial purposes, I would re evaluate.
/ 3 PH splitter questions #12
The volume of fluid in a 4 in bore , 24 in cyl is 1.31 gal
--------------------------5 ------------------------2.04 gal
Wow JJ, I'm amazed it's that high!!!
I happened to be talking to a friend while shooting some pool, who happened to mention that he had a 3 pt splitter that he wasn't using any longer. It had come with the house that he bought and he had used it for a while, but decided that he wanted a stand alone splitter, so the 3 pt was just sitting.
So, now it's sitting @ my house:cool2:
I believe that it's an old North Star or Northern Tools splitter, but I'm not absolutely sure about that.
I brought it home, hooked it up (he was running it off of a Kioti with the same hyd fluid that I was using) and split all of the pile of "too big to burn" logs that I had setting there. It's not incredibly fast, but I'm in no hurry.
Here's the specs:
Cylinder diameter 3.5
Rod diameter 1.5
Stroke 24
Pressure 2700psi
Flow 12gpm (approx, 16.8gpm total and using J_J's estimate of 4gpm for steering)
My handy-dandy calculator app says about 12 tons of pressure, which appears to be plenty, as the red oak and beech presented no problem at all.
Now, for the next question . . . . :D
The valve on this splitter has to be held in both directions. I would like to replace it with one that has a detent on the return stroke and then turns off when the rod has fully retracted.
I know zero about hydraulics, but feel competent enough to replace this cylinder . . . . IF I knew which cylinder I needed to get.
Can someone point me in a direction to find one of these? Is there additional information required to determine which valve will work on this splitter?
Thanx,
Keith
/ 3 PH splitter questions #17
I have a power horse 3pt 2 way splitter. Love it as there is no "cycle time". It is a 20 ton and so far splits anything I throw at it.
Giyi SGB20 QA Stump Bucket (A60463)
Giyi SGB20 QA...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
2020 VOLVO VNL760 6X4 T/ A SLEEPER TRUCK TRACTOR (A59906)
2020 VOLVO VNL760...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
2008 JACK COUNTY 130 BBL VACUUM  TRAILER (A60736)
2008 JACK COUNTY...
