3 hrs on 2015 NX4510 and check engine light is on after missing Regeneration
   / 3 hrs on 2015 NX4510 and check engine light is on after missing Regeneration
I have a question who is they and we?Glad to hear you have your problem resolved.
Yeah I can see how that was confusing. I edited it for clarity, it is tough to type long paragraphs on my phone.
Threepoint, the tractor is back in my drive way it was retested this morning and everything is clear. But yes I could not believe it when the light came on. Talk about disappointing I research for months before getting this tractor, but both Kioti and Van Paemel were excellent to deal with. And it is going to be torture waiting until I can start plowing, ill be sure to keep in contact. I am going to have some more questions down the road, and a lot of projects.
Eric, Was that a manual burn or the automatic one? I will post the directions from the Kioti in a few minutes. The automatic I was told to raise the RPMs manually as you stated before. I have a print out on the regeneration cycle and it explains all of the parts of the exhaust and how they work.
Summary run the tractor at or near PTO speeds or a "working load" and your exhaust gas temperature will burn the particulate matter.
Auto: 80-100% Particulate matter in the trap will initiate the automatic regeneration. You need to reach and stay at above 1500 rpms or the regeneration cycle will stop. The regeneration cycle will last approximately 20 minutes. The regeneration underway lamp will be lit during the process, do not shut the engine off until the regen underway lamp is off.
Manual has to be initiated after the particulate matter has gone above a 100% in the trap: Start and run at idle 3 to 4 minutes coolant temp needs to reach 68F. Lock parking brake, do not depress the clutch pedal, place range level in neutral. Press regeneration button, hold for two seconds. Regen underway lamp will blink after the regen warning right turns off. Regen will take around 40 minutes, 12 to warm up, 25 to regen, 3 to cool down.
If you reach over a 101% PM in the trap you will see a 30% reduction in torque until you initiate a manual burn. Seems pretty fair actually.
   / 3 hrs on 2015 NX4510 and check engine light is on after missing Regeneration #54
The reduction in torque stinks. I went into my Kioti NX knowing about it but the excessive warm up time connected to my type of use, led to zero automatic regen cycles.
As a result, I popped in a warmer thermostat and that change seems to have worked out wonderfully.
   / 3 hrs on 2015 NX4510 and check engine light is on after missing Regeneration #55
Boy, am I glad I got my tractor last year.
   / 3 hrs on 2015 NX4510 and check engine light is on after missing Regeneration #56
Yeah, what a ridiculous way to reduce emissions. In a few years all this stuff will be replaced by something less absurd, one can hope.:confused3:
   / 3 hrs on 2015 NX4510 and check engine light is on after missing Regeneration #57
Isn't there a way to disable all this tier 4 carp? I don't have a tier 4 to know beans about it.
   / 3 hrs on 2015 NX4510 and check engine light is on after missing Regeneration #58
Federal law prohibits tampering with or disabling any emissions related controls, and provides stiff penalties, fines, and jail time. Beheading Tier 4 carp is not covered, though....
   / 3 hrs on 2015 NX4510 and check engine light is on after missing Regeneration #59
Beheading Tier 4 carp falls under the Fish and Wildlife Service. Not a problem as long as they are in season and you have a permit :D
Aaron Z
   / 3 hrs on 2015 NX4510 and check engine light is on after missing Regeneration #60
Aaron Z
Mmmm! Fish-head soup with a side of kimchi!
Call me crazy, but I actually like my Tier IV carp. :)
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A55852)
2014 Peterbilt 384...
UNUSED IRGC40 MINI ELECTRIC GOLFCART (A57193)
UNUSED IRGC40 MINI...
2016 Chevrolet Traverse LT SUV (A55853)
2016 Chevrolet...
UNUSED LANHERO LDH-SP50 50 TON HYD SHOP PRESS (A57193)
UNUSED LANHERO...
UNUSED WOLVERINE MAD-12-12D HYD AUGER DRIVE & BIT (A57193)
UNUSED WOLVERINE...
2015 Freightliner Cascadia 125 T/A Wet Kit Day Cab Truck Tractor (A55852)
2015 Freightliner...
