3 cytl perkins oil galley plug help
   / 3 cytl perkins oil galley plug help #1
370
kouts, IN
massey ferguson mdel 20 industrial
so I've got a industrial 20 and its got a 3 cyl perkins gas. It had a nasty oil leak and less than stellar oil pressure so I pulled the engine and sure enough the oil galley plug was leaking. SO I've got a new plug but I'm not really sure how to get the old one out. slide hammer? it looks as if it was driven in from the front of the engine or the plug was driven in backwards. I'm going to include 2 pictures.
but it turns out I need to have 5 posts before I can post a link sooooooooooooooooooo heres post #2
and post #3
quattro
almost there......#5
you can't really see the silver arrow I drew quite as good in the second picture.. looks more like a silver line.. but it's there on the left side
   / 3 cytl perkins oil galley plug help #7
Drill a small hole, screw a good size sheet metal screw into the hole and pull, better if you could us a slide hammer on the screw but it should come out with a bit of wiggling......Mike
2019 KUBOTA U35-4 EXCAVATOR (A51246)
2019 KUBOTA U35-4...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
UNUSED JCT QUICK ATTACH DIGGER ARM (A51248)
UNUSED JCT QUICK...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
2014 International PayStar 5900i S/A Flatbed Truck (A52377)
2014 International...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
