3 cytl perkins oil galley plug help
   / 3 cytl perkins oil galley plug help #1
370
kouts, IN
massey ferguson mdel 20 industrial
so I've got a industrial 20 and its got a 3 cyl perkins gas. It had a nasty oil leak and less than stellar oil pressure so I pulled the engine and sure enough the oil galley plug was leaking. SO I've got a new plug but I'm not really sure how to get the old one out. slide hammer? it looks as if it was driven in from the front of the engine or the plug was driven in backwards. I'm going to include 2 pictures.
but it turns out I need to have 5 posts before I can post a link sooooooooooooooooooo heres post #2
and post #3
quattro
almost there......#5
you can't really see the silver arrow I drew quite as good in the second picture.. looks more like a silver line.. but it's there on the left side
   / 3 cytl perkins oil galley plug help #7
Drill a small hole, screw a good size sheet metal screw into the hole and pull, better if you could us a slide hammer on the screw but it should come out with a bit of wiggling......Mike
UNUSED AGT TSOCPF48 MAST W/ 48" FORKS (A51248)
UNUSED AGT...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
UNUSED HURRICANE 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
WORKSAVER RMB-325-PW LOT IDENTIFIER 105 (A53084)
WORKSAVER...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
