2wd vs 4wd
/ 2wd vs 4wd #1
wango tango
Peoria IL
I bought a Great Plains 3P606NT last year. My JD 4720 can lift it but it squats hard, even with the front ballasted with the loader.
I'm toying with getting an open station 2wd no loader 5325. It would be dedicated to my drill and bushhog. I'd use the extra funds from the 4720 sale for a skid loader or mini ex....decisions decisions....
Guessing a 5325 has a good bit more 3pt lift capacity? The one I'm looking at has 4 suitcase weights on the front. The other plus is the 5325 is about 11k and I could get 30+ for my 4720.
I am now thinking that if you need 4wd you should not be planting. Would others agree? Effectively rendering 4wd a moot point for my application? Agree or disagree?
/ 2wd vs 4wd #2
Agree about 2wd and planting, but will you need 4wd for other work?
/ 2wd vs 4wd #3
One of your earlier posts, September 2019, mentions you have a CAB JD4720. With a heavy drill on the Three Point Hitch and 2-ply R1/ag tires of coarse the cab tractor will squat.
With 6-ply R4/industrial tires providing more sidewall support it would squat less but you would have less traction.
Which tires do you have? Are all four tires inflated to recommended pressures? Are rear tires filled with liquid or air?
Is tire squat your main issue? How old are your tires?
/ 2wd vs 4wd #4
Did field work for years with a 2wd tractor. Only have the 4wd tractor in 4x4 to do tillage. I seed in 2wd.
The 5325 you are looking at does not have a loader...so 2wd is fine.
/ 2wd vs 4wd #5
Wil the front weight bracket accommodate more weights? You probably will need more. Will the drill cover the width of the wheel tracks? Other than that I think you will be fine, just stay out of wet spots.
/ 2wd vs 4wd
Has r4 with beet juice. 2012 tires.
/ 2wd vs 4wd
Planning on a skid loader for other work. The FEL on my 4410 and 4720 feel flimsy. Combine that with general clumsiness and I just want to replatform to a much more capable machine. Like a skid loader.
/ 2wd vs 4wd
Yes, looks like it will.
/ 2wd vs 4wd #9
I hear you.
I am constantly “tweaking” my farming & contracting operation. I will probably have everything right about 1 year before I retire. :laughing:
/ 2wd vs 4wd
My 4720 is 2500 lbs. The 5325 should lift my drill ok. Like I said my 4720 does but squats. I only get a few inches or clearance.
/ 2wd vs 4wd
I assume a 2wd 5325 with R1s would have the same pulling ability as my 4720 with MFWD and R4’s. Thoughts? I’m just always worried that 2 wheel drive will not be enough but again this is only going to be used to drill and bushhog. Probably should not be in the fields if it’s that wet I guess. That’s my logic.
Thoughts?
/ 2wd vs 4wd #13
Thoughts?
I think youre probably over thinking this, but then again I dont know how either rig is weighted, tire condition, loader, etc. Pictures would really help. I think you have a sound plan, but remember, the weather wont always cooperate. Thats in Gods hands. If ground is slightly wet, you may still have to bush hog.....whats the bush hog property look like? Hilly? Damp? I mow hundreds of acres of conservancy meadows, which can be challenging even if it rained several days prior to mowing. Nice thing about 4WD is you wont have spinning tires if you must "go" shortly after rain.
Does the 5325 have real fresh deep rubber? Weights? That will make a difference.
My ground is too hilly for 2WD, so my decision is made for me.
/ 2wd vs 4wd #15
/ 2wd vs 4wd
About 2800-3100 I’d guess. Drill is 2500ish empty. Depending on seed load.
/ 2wd vs 4wd #17
Well, I think you are going too small, but it’s easy for me to spend your money.
Tractor data says 3pt lift capacity 3375lbs at 24” Total tractor weight is only ~6,000lbs
Once full of seed, I think you’ll be at capacity.
If I were in your situation, I’d go to an older 80-100HP tractor with more frame and weight without hesitation. There’s a plethora of those tractors sitting around for sale.
/ 2wd vs 4wd
I appreciate your wisdom!
Found a 1978 allis chalmers 185 with 2k hours and a lot of replaced stuff for $7k. Bonus is it’s right by my farm!
I can’t find 3 pt lift capacity though....
/ 2wd vs 4wd #19
It’s not a heck of a lot more tractor than the 5325.
I’d keep looking
/ 2wd vs 4wd
Any models you’d think would be a good fit? Go ahead and spend my money. It’s ok. :)
I just don’t have much to spend!
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
2006 LeeBoy L8510R Low Deck Asphalt Crawler Paver (A66734)
2006 LeeBoy L8510R...
PALLET OF 51 X 41 X16 BRASS WEAR RINGS (A68842)
PALLET OF 51 X 41...
2022 HLA 54in. Hydraulic Root Rake Grapple Attachment (A66734)
2022 HLA 54in...
PORTA POTTY (A67714)
2015 Case TR320 (A64911)
2015 Case TR320...
