2wd TD owners
   / 2wd TD owners #1
LaneFarms
north florida
Is anyone with a 2wd TD with a loader on it having front end problems. My drag link is rubbing the bottom of the front end housing, wearing a groove in it. It has also caused 2 drag links to be bent like a pretzel.
   / 2wd TD owners #2
My td is 4 wheel drive so it's a lot different. I can't imagine the drag link rubbing on anything unless something isn't installed right, or bent. I looked at the diagram for the 2 wheel one and it doesn't look like it is possible to rub.
   / 2wd TD owners #3
You 've got a lot of damge to your front end. You must be overloading your loader or you've hit something while having a big load on it. Stop using it and fix it before you're into some big $ repairs.
   / 2wd TD owners
The tractor is still under warranty it only has 400 hours on it. The biggest load I have picked up with it was a 6ft bucket full of dirt. I noticed NH now installs the 810 on these tractors where I have the 820. Mostly this tractor is used to load hay.With no load on the loader there can't be 1/4" clearance between the drag link and the frame. When you load it they touch.
2008 Volvo XC90 SUV (A51694)
2008 Volvo XC90...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
2010 Chevrolet HHR SUV (A51694)
2010 Chevrolet HHR...
UNUSED AGT SDA 140W WHEEL LOADER (A51247)
UNUSED AGT SDA...
2014 CATERPILLAR 349FL EXCAVATOR (A51246)
2014 CATERPILLAR...
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
