2wd TD owners
   / 2wd TD owners #1
LaneFarms
north florida
Is anyone with a 2wd TD with a loader on it having front end problems. My drag link is rubbing the bottom of the front end housing, wearing a groove in it. It has also caused 2 drag links to be bent like a pretzel.
   / 2wd TD owners #2
My td is 4 wheel drive so it's a lot different. I can't imagine the drag link rubbing on anything unless something isn't installed right, or bent. I looked at the diagram for the 2 wheel one and it doesn't look like it is possible to rub.
   / 2wd TD owners #3
You 've got a lot of damge to your front end. You must be overloading your loader or you've hit something while having a big load on it. Stop using it and fix it before you're into some big $ repairs.
   / 2wd TD owners
The tractor is still under warranty it only has 400 hours on it. The biggest load I have picked up with it was a 6ft bucket full of dirt. I noticed NH now installs the 810 on these tractors where I have the 820. Mostly this tractor is used to load hay.With no load on the loader there can't be 1/4" clearance between the drag link and the frame. When you load it they touch.
21010 (A51694)
21010 (A51694)
2016 CATERPILLAR 303.5E2 CR EXCAVATOR (A51246)
2016 CATERPILLAR...
(1) UNUSED 7000# DROP AXLE W/ BRAKES (A51247)
(1) UNUSED 7000#...
40' CONTAINER (A51248)
2024 JOHN DEERE 8RX310 LOT NUMBER 212 (A53084)
2024 JOHN DEERE...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
