2WD & 4WD Selector
   / 2WD & 4WD Selector #1
tangles
2004 Jinma 254
The selector on My Jinma 254 is stuck in 4WD. Any suggestions on what I can do? The selector gets half way but won't go further and I don't won't to force it I case I damage something. It should just move between the 2 easily.
   / 2WD & 4WD Selector #2
try shifting while creeping along. it may be something as simple as driveline run up from when it was parked.
if that don't help I'd jackup all 4 and place in neutral and block clutch and get a helper to wiggle tires to and from while you play with selector.
post back.
soundguy
   / 2WD & 4WD Selector #3
I have had to "rock" my Kubota before. Just barely hit the reverse pedal while applying steady pressure to the lever, then go back forward. As soundguy said, things can get a bit bound up. Also, may want to drive it on a more slick surface. Mine has the most trouble on pavement.
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
Kivel 48'' pallet fork attachment, 3500# capacity (A53421)
Kivel 48'' pallet...
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
2008  BIG TEX 16' T/A TRASH TRAILER (A53843)
2008 BIG TEX 16'...
