2nd oil change
/ 2nd oil change #1
chuck172
Platinum Member
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
Help me understand. The kioti manual says the first oil change must be at 50 hours. According to the manual, should the second be at 100 hours on the meter or 100 hours past 50, meaning at hour 150?
/ 2nd oil change
So that would mean at hour 150, right?
/ 2nd oil change #4
Yes. If you go longer than one season(year) between the 100hrs. might consider changing at the end of each season.
/ 2nd oil change #5
I changed mine again at 100 hours. It now has 300 hours, and that reminds me. I need to change the oil!
/ 2nd oil change #6
I did the same as you.
/ 2nd oil change #8
Kioti is in with the oil lube people or slow with the manuals (we know that) the older tach hour Kioti have the same 100 engine oil change as the newer clock tach Kioti's and depending on how fast the engine get run oil changes can come due quite a bit sooner. I think 150 hours is about right for the engine, My New Holland TN55 has a 300 hour oil clock oil change, I use 150hr.
2012 18ft Gastron Boat with 18ft Magic S/A Boat Trailer. (A64557)
2012 18ft Gastron...
2008 R&R FLATBED WINCH TRAILER (A65643)
2008 R&R FLATBED...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
New/Unused Wolverine Quick Attach Hydraulic Rock Rake (A65583)
New/Unused...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
