2nd oil change
/ 2nd oil change #1
chuck172
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
Help me understand. The kioti manual says the first oil change must be at 50 hours. According to the manual, should the second be at 100 hours on the meter or 100 hours past 50, meaning at hour 150?
/ 2nd oil change
So that would mean at hour 150, right?
/ 2nd oil change #4
Yes. If you go longer than one season(year) between the 100hrs. might consider changing at the end of each season.
/ 2nd oil change #5
I changed mine again at 100 hours. It now has 300 hours, and that reminds me. I need to change the oil!
/ 2nd oil change #6
I did the same as you.
/ 2nd oil change #8
Kioti is in with the oil lube people or slow with the manuals (we know that) the older tach hour Kioti have the same 100 engine oil change as the newer clock tach Kioti's and depending on how fast the engine get run oil changes can come due quite a bit sooner. I think 150 hours is about right for the engine, My New Holland TN55 has a 300 hour oil clock oil change, I use 150hr.
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
2022 EZ-GO ELITE...
UNUSED ATSPOWER STAND-ON SKID STEER (A64280)
UNUSED ATSPOWER...
2017 Ford Expedition SUV (A61574)
2017 Ford...
JOHN DEERE 7930 TRACTOR (A64280)
JOHN DEERE 7930...
New Holland TC21 (A62177)
New Holland TC21...
