2N carburator question
   / 2N carburator question #1
David Wayne
Central Ohio
Kubota L3400
I have purchased a 1946 2N. It needs carb work done so I looked at what it has on it. It is a Marvel TSX 751 not the usual 33, the 751 is listed for a Massey Ferguson model 32 Chrysler industrial. Does anyone on here know if there is any difference in the casting of a 33 vs 751? Can I take a rebuild kit for a 33 and put it in a 751 thus making it a 33?
Thanks David
   / 2N carburator question #2
If it uses the same gasket as many small Ms carbs, then 'probably'
May or may not have economizer, and son larger carbs use different jet setup.
Pop it open, you will immediately know.
Compair needles, etc.
Thanks soundguy, they do look the same inside. I had it apart to adjust the float & replaced the float valve with a used one I had.
I will have to look up "economizer" not sure what that is.
David
   / 2N carburator question #4
economizer jet ( in the top part of the carb ) MAY not have been used on a tsx33 but was on a 241 B? Not sure about other MS carbs. MS made sooo many carbs for soo many tractors. all very similar, that's why some swappings work fine, some don't.
   / 2N carburator question #5
here's a write up by a couple friends of mine.
GB in montana and Jmor ( jessie )
M/S TSX Carburetor
should explain some of the differences
The carb is the right carb. Its a 241b not a 751. I believe the 751 is a date code
   / 2N carburator question #7
Yup, b for best..
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2013 FORD F450 XL SUPER DUTY BUCKET TRUCK (A51406)
2013 FORD F450 XL...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
John Deere (A50322)
John Deere (A50322)
