2950 lost gears
/ 2950 lost gears #1
Windsweptfp
Winchester, Ky
John Deer 2950
We have JD 2950 that has lost pulling power in low & high range gears. Will only pull a load when in the "rabbit " gear range.
Can anyone explain what caused this, what it will take to repair, & how much it could cost.
Thanks
/ 2950 lost gears #2
Welcome to TBN
Sounds as if you've lost hyd pressure or clutch plates in low(turtle) side of hyd hi-lo. I'll suggest to check pressure on top of valve housing on top of clutch housing. Pressure should be 155-165 psi. Another thought is a shift linkage problem. Does your tractor have a cab?
/ 2950 lost gears #4
Repair to hi-lo requires tractor to be split
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
2015 DODGE CHARGER CAR (A66091)
2015 DODGE CHARGER...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
3 PALLETS OF SNOW CHAINS (A66091)
3 PALLETS OF SNOW...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
