2950 lost gears
/ 2950 lost gears #1
Windsweptfp
Winchester, Ky
John Deer 2950
We have JD 2950 that has lost pulling power in low & high range gears. Will only pull a load when in the "rabbit " gear range.
Can anyone explain what caused this, what it will take to repair, & how much it could cost.
/ 2950 lost gears #2
Welcome to TBN
Sounds as if you've lost hyd pressure or clutch plates in low(turtle) side of hyd hi-lo. I'll suggest to check pressure on top of valve housing on top of clutch housing. Pressure should be 155-165 psi. Another thought is a shift linkage problem. Does your tractor have a cab?
/ 2950 lost gears #4
Repair to hi-lo requires tractor to be split
2007 KENWORTH (INOPERABLE) T880 (A67714)
2007 KENWORTH...
Kubota L275 (A64911)
2015 WILDWOOD 5TH WHEEL (A67714)
2015 WILDWOOD 5TH...
Swict 8' Fork Extensions (A64912)
Swict 8' Fork...
Eagle Line Equipment 3pt Single Row Plow (A64912)
Eagle Line...
2005 Bobcat B950 Hydraulic Breaker Skid Steer Attachment (A66734)
2005 Bobcat B950...
