2950 deere; raising lift arms bogs tractor/pecking sound
   / 2950 deere; raising lift arms bogs tractor/pecking sound #1
curt in ky
I went to look at a 2950 with cab today and when I started it I noticed a pecking sound. When you raised rpm's it would quiten down. Almost sounds like the front hydrualic pump. Then when I raised the lift arms the pecking sound went away but the tractor bogged down bad. Does that sound like the hydraulic pump or something else? I'm familiar with 06-86 series IH and don't know much about deere's. Do they just have the one pump in front of the engine? This tractor did not have the hi/lo. Thanks.
   / 2950 deere; raising lift arms bogs tractor/pecking sound #2
Check hyd stand-by pressure. Hyd hi-lo was an option. You do realize the hi-lo control is integrated in the speed change lever on a 2950 SGB(cab) tractor? Pecking noise could be a worn hyd pump drive coupler.
   / 2950 deere; raising lift arms bogs tractor/pecking sound #3
I agree with txJim. Sounds like you have a worn pump coupler. Either cushion #3 is worn or shaft #6 is loose on splines of hydraulic pump shaft. Checking pressure is a good idea, although it is normal for rpm's to drop when raising rockshaft. The pump is providing a large volume of oil to lift rockshaft. There are two pumps involved here. The transmission pump needs to provide oil for engaging pto cluth, pto brake, (hi-lo and mfwd if equipped) lubing transmission, and any leftover flow supplies oil to main pump.
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
2023 BOBCAT T62 COMPACT SKID STEER TRACK LOADER (A55218)
2023 BOBCAT T62...
DITCH WITCH FX30 VACUUM TRAILER (A51406)
DITCH WITCH FX30...
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
2012 FREIGHTLINER DURASTAR 4300 M7 SBA 4X2 BUCKET TRUCK (A51406)
2012 FREIGHTLINER...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
