293 loader or quick attach problem, please see pics
/ 293 loader or quick attach problem, please see pics #11
If it didn't twist the loader fork frame, how did it twist the FEL. I have mistreated the heck out of my FELs lifting the one or both rear wheels off the ground and never twisted a frame like that. I don't think if was from overloading unless you have a poorly designed FEL. Most likely is that one side wasn't locked in and that is what caused the twisting. I always like to look at the bottom pins to assure that they are protruding thru before using an attachment when I switch out with the bucket.
/ 293 loader or quick attach problem, please see pics #12
This is good to know. I just bought a 2010 T293 so everything I can learn about it helps.
I'm guessing the pins weren't in all the way? The tubing would have been causing the feet to become out of plane. Regardless, fairly easy fix and I double check the pins now.
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A61307)
2021 Unverferth...
Service Truck Body (A59230)
Service Truck Body...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
2013 FORD F250 (A60460)
2013 FORD F250...
2017 FREIGHTLINER CASCADIA WRECKED (A60736)
2017 FREIGHTLINER...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
