2816 106 loader leak
/ 2816 106 loader leak #1
Sackamous
I am new to tractors an just picked up a 2816 for some deer food plots and small things around the house. I noticed I got a leak on the loader controle stick. It's comeimg from behind the quick connect with the blue zip tie on it. My question is do I need to just pull the fitting and tape it up and tighten it down? Is there maybe an o ring under it leaking? If I pull the fitting will flud come poreing out? Sorry for my ignorance in this subject I'm am new to this after all.
/ 2816 106 loader leak #2
Relieve the pressure by rotating your joy stick. You should'nt lose any fluid. Simply loosen the fitting, and disconnect it. Check for debris in the threads, or cross threading. My guess is it is just loose. If you can tighten it with a crescent wrench before you do the above, you will have fixed it.
So the fitting on the bucket controler is just a threaded fitting. No o rings or anything. It looks to be a stainless fitting so I think I will take it out and tape it up. Sure would hate to gaul it trying to just tighten it up. Thanks much for the info.
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
JOHN DEERE 323E SKID STEER (A64279)
JOHN DEERE 323E...
New Holland TS6030 (A64119)
New Holland TS6030...
UNUSED AGT YC-32G SAWMILL (A64281)
UNUSED AGT YC-32G...
HONDA WP40X 3" WATER PUMP (A64281)
HONDA WP40X 3"...
