2815 HST?
/ 2815 HST? #1
MDM
Platinum Member
East Ohio
Kubota L2800HST
Are there any 2815HST owners on here? I've searched and can't find anyone who has bought a 2815 and have only found 1 or 2 posts from people who have bought a 3215 HST.
Dealers - Are you guys selling many of the 2815s? I looked at this tractor a couple of weeks ago and I like it, but would like to hear from actual owners. Will the 2815 run a 6' finish mower? Is the hood plastic on the 2815? I noticed the plastic fender flares. Are their tubes in the tires? I would want to add windshield washer fluid to the rears, but don't want to damage the rims.
/ 2815 HST? #2
I don't own one ...yet, if I can sell my 2015 hst I plan on purchasing a 3215 hst.
I don't think the 2815 will have any problem with the 6' mower
Yes, the hood is plastic but it seems to be a good design
I feel sure the tires are tubeless.
/ 2815 HST?
Another question. How is the PTO engaged on the 2815? Is it by the flip of a switch or do you use the clutch to engage? I'm hoping the latter.
/ 2815 HST? #4
My 2615 runs a 6' rfm no problem so I'm sure the 2815 will do fine also. I can't say anything as far as the plastic hood is concerned, 2615 is metal. My 2615 has tubless tires, so I'm guessing the 2815 does also!
/ 2815 HST? #5
MDM, if I'm not mistaken all the 15 series are made by Mitsubishi and the PTO is engaged via clutch and lever.
/ 2815 HST? #6
The 2815 hst & 3215 hst use a clutch and manual lever to engage the pto and the 3215 shuttle shift has independent electric over hydraulic clutch engagement.
The 2815 hst should have no problem with running the 72" finish mower. I have customers running 72" finish mowers with 2310 tractors with no problem and I have a customer who runs a 84" mower with a 3015 hst.
Galen LaWall
Your Mahindra Tractor Dealer
Batavia NY 14020
585-343-0770
/ 2815 HST? #7
You guys have any preference on Independent pto or clutch/live?
/ 2815 HST? #8
With the HST, the clutch runs the PTO, yet the tractor travel is done with the hydro pedal. Essentially, the PTO and tractor travel become independent of one another, with the exception of everything stopping when the clutch is depressed. It's a nice system for HST tractors. If you want to stop but keep the mower going, just don't depress the clutch. You basically have an independent PTO, yet it is very simple.
As far as the two stage clutch on the 2615 4wd vs the iPTO on the 3215 4wd, the iPTO is a better system in my opinion. Both work great, but 2 stage clutches always release higher which is a little bit annoying if you are used to a lower release point.
2015 Volvo L30GS (A62180)
2015 Volvo L30GS...
2021 ASV RT-120 FORESTRY SKID STEER (A65053)
2021 ASV RT-120...
KUHN GA4121GM 11' ROTARY HAY RAKE (A64277)
KUHN GA4121GM 11'...
Pallet of 12 Metal Shelves (A65579)
Pallet of 12 Metal...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 FREIGHTLINER...
ATS ATS-PC90 Heavy Duty Plate Compactor (A62679)
ATS ATS-PC90 Heavy...
