2810HST - Tach stopped
   / 2810HST - Tach stopped #1
shvl73
Banned
NH
Mahindra 2810HST
My '03 2810HST has only 355hours. Last week the tach was erratic and this week it has stopped working competely. All other gauges work. Any ideas on what to look for?
   / 2810HST - Tach stopped #2
That is all the symtoms of a broken tach cable.
hugs, Brandi
Now that you mention it, that makes sense. For some reason, I thought it was electrical, not mechanical. I was rushing to get things done and haven't had a chance to look at it. I'll check it out this weekend.
Thanks
   / 2810HST - Tach stopped #4
Thanks
Don't know about your model but my 4110 has an electrical tach, no cable. I could be mistaken but I think it reads off the altenator. My tach started acting-up 2 winters ago - doesn't work when cold, then slowly will start reading as it warms up several minutes. No problems in warmer weather (above 35 degrees or so) and seems to be accurate still.
Well, that complicates things a little. Mine has just started doing it recently. How did you find which wire? It could just be a bad connection or loose.
   / 2810HST - Tach stopped #6
Interestingly enough the tach on my 3510 (2004 model) has begun acting up recently and current hours are about 360. Sometimes it doesn't move at all and sometimes it goes all the way around to the stop! Seems that tapping the dash panel or shutting down and restarting after it has warmed up and it usually begins to read correctly, alathough sometimes it just begins reading correctly with no intervention after a few minutes.
I hope to take the dash out this weekend and see what lies beneath. I hope to find a loose wire.
   / 2810HST - Tach stopped #8
I would be interested to know of your findings. If time permits I may do a little exploratory surgery as well!
I took it apart last night. There is alot of electronics in there. The tach is electrically driven. I didn't see any loose wires :( . Without much technical knowledge, I'm thinking it's going to be a dealer repair. Do any of the dealers here have any suggestions? Is the tach a separate item or will I need to get the whole dash cluster?
Update: the tractor wouldn't start this afternoon. Battery was low. I charged it and started it up and checked the alternator, not charging. Well, where do I go from here? I'm guessing that I could check and see if it can be rebuilt. Has anyone done so?
(1) TIRE & WHEEL (1) TIRE, STEER TIRES 11R22.5 (A51244)
(1) TIRE & WHEEL...
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
Kubota F3990 72in Front Mower (A50322)
Kubota F3990 72in...
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
2014 Ford F550 Dump (A47384)
2014 Ford F550...
(3) UNUSED FUTURE JUMPER CABLES (A51243)
(3) UNUSED FUTURE...
