2800 lift height
/ 2800 lift height #1
vulcan101
alabama
kubota L2800
since i had the lift valve replaced under warranty for the jerkiness i have noticed the attachments will only lift about 18"-24" off the ground.before the attachments would lift 3'-4' is their an adjustment on the lift height? as sometimes i cannot lift boxblade high enough to get over small dirt piles. very frustrating.
/ 2800 lift height #2
Have you changed the position on your top link? Use the lower hole to create a higher lift on the implement. I don't know if the valve replacement would cause this. I have ignored all the hype and left mine alone. I never noticed anything wrong with. I can always raise it and then lower it to any microadjustment I want.
/ 2800 lift height #3
If it was adjusted properly after the valve replacement then there shouldn't be any difference between the old valve and the new one. Here is a thread explaining the adjustment. 3pt adjustment
/ 2800 lift height #4
Your lift needs adjustment. I had to take my 2800 back and they readjusted for height. Makes ya wonder why they didn't get it right the first time.
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
121A (A63745)
121A (A63745)
2022 EZ-GO ELITE...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
