Backhoe 28 XL HST with FEL and BH
   / 28 XL HST with FEL and BH #1
BudMan5
SW MO
Mahindra 28XL HSTJD 915E and JD D140
My 28XL HST has about 95 hours on it. The backhoe has lost it's smooth movements and is instead quite a bit during movement. I am assuming this is a hydraulic issue. The owner manual is pretty useless. Is the hydraulic fill for the transmission located below the seat the same hydraulics used for the FEL and BH? Thanks for any advice.
   / 28 XL HST with FEL and BH #2
Yes fill and dipstick is below seat. Have you check hyd. oil level yet?
   / 28 XL HST with FEL and BH #3
They share the same hydraulic fluid. The location is posted above.
Sometimes a quick connect will come lose or get something stuck in it and cause changes in the way it functions. Especially if everything else is smooth.
   / 28 XL HST with FEL and BH #4
Yes, ^^^^ this, check your hydraulic connections.
The dipstick shows on the low end, fluid is remarkably clean. I will pick up fluid today and get it brought up to the high mar. I am guessing that will be several quarts worth due to the large volume needed to fill an empty chamber.
MANY thanks for the replies!
2012 JOHN DEERE 850K WT CRAWLER DOZER (A51242)
2012 JOHN DEERE...
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
2014 Jacobsen AR3 Commercial Mower (A50322)
2014 Jacobsen AR3...
E-Z Flow Auger Wagon (A50514)
E-Z Flow Auger...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2008 CATERPILLAR 314CL CR EXCAVATOR (A51242)
2008 CATERPILLAR...
