Backhoe 28 XL HST with FEL and BH
   / 28 XL HST with FEL and BH #1
BudMan5
SW MO
Mahindra 28XL HSTJD 915E and JD D140
My 28XL HST has about 95 hours on it. The backhoe has lost it's smooth movements and is instead quite a bit during movement. I am assuming this is a hydraulic issue. The owner manual is pretty useless. Is the hydraulic fill for the transmission located below the seat the same hydraulics used for the FEL and BH? Thanks for any advice.
   / 28 XL HST with FEL and BH #2
Yes fill and dipstick is below seat. Have you check hyd. oil level yet?
   / 28 XL HST with FEL and BH #3
They share the same hydraulic fluid. The location is posted above.
Sometimes a quick connect will come lose or get something stuck in it and cause changes in the way it functions. Especially if everything else is smooth.
   / 28 XL HST with FEL and BH #4
Yes, ^^^^ this, check your hydraulic connections.
The dipstick shows on the low end, fluid is remarkably clean. I will pick up fluid today and get it brought up to the high mar. I am guessing that will be several quarts worth due to the large volume needed to fill an empty chamber.
MANY thanks for the replies!
International 5488 2wd Tractor (A52128)
International 5488...
2019 CATERPILLAR 272D2 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A51244)
UNUSED FUTURE MINI...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
