Backhoe 28 XL HST with FEL and BH
   / 28 XL HST with FEL and BH #1
BudMan5
SW MO
Mahindra 28XL HSTJD 915E and JD D140
My 28XL HST has about 95 hours on it. The backhoe has lost it's smooth movements and is instead quite a bit during movement. I am assuming this is a hydraulic issue. The owner manual is pretty useless. Is the hydraulic fill for the transmission located below the seat the same hydraulics used for the FEL and BH? Thanks for any advice.
   / 28 XL HST with FEL and BH #2
Yes fill and dipstick is below seat. Have you check hyd. oil level yet?
   / 28 XL HST with FEL and BH #3
They share the same hydraulic fluid. The location is posted above.
Sometimes a quick connect will come lose or get something stuck in it and cause changes in the way it functions. Especially if everything else is smooth.
   / 28 XL HST with FEL and BH #4
Yes, ^^^^ this, check your hydraulic connections.
The dipstick shows on the low end, fluid is remarkably clean. I will pick up fluid today and get it brought up to the high mar. I am guessing that will be several quarts worth due to the large volume needed to fill an empty chamber.
MANY thanks for the replies!
2012 Freightliner Cascadia 113 Semi (A50514)
2012 Freightliner...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
Bush Hog 2615 Rotary Cutter - INOPERABLE / PARTS ONLY (A52128)
Bush Hog 2615...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A52128)
2022 New Holland...
New Holland TS6.120 4WD Agricultural Tractor (A50322)
New Holland...
